Hi ,
I need somme help for a methode to create a fixture for a roboscan PRO918 on a FATFROG, with the dimmer separate.
I try to modify the MARTIN fixture PRO918(mode4) .
but this not a succes...
in my conclusion i want two dmx adress for this fixture.
-one for the dimmer
-and the second for all other parameters.
Thank you for you answers, and sorry for my aproximalty english!
Hi laguii,
On that fixture, the dimmer channel isn't at the beginning or the end of the profile, meaning this isn't as easy to do this. You would need to patch this as three separate fixtures - One for the shutter channel, one for the dimmer, and then one for the rest of the profile.
If you would like to do this, let me know and I'll edit the fixtures for you.
Thanks
Jon
