remco535 Posted June 16, 2014 Report Posted June 16, 2014 Hi everyone, I recently bought the zero88 Jester ML24. The table works well altough I have a problem, probably with tagging. I want to create 3 chases on 3 different submasters. One program with 8 static lights - ADJ flat par on 3ch One program with 4 movingheads - Showtec phantom 50 LED and one program where all fixtures are white flashing . All fixtures are working properly. We want to have 3 independent submasters so one with the static lights, where the submaster fader acts as dimmer, one with the moving lights and one to throw on to have all lights flashing. The problem we encouter is that when we program and we run them, we are not able to use the submasters independent, its or the statics, or the moving lights but not the two together running independently. We think we make a mistake with the tagging system. does anyone have an idea about what we are doing wrong? Help is appreciated Remco Quote
Jon Hole Posted June 16, 2014 Report Posted June 16, 2014 Hi Remco, Please could you upload a version of your showfile please? Many Thanks! Quote Jon Hole linkedin.com/in/jonhole
