You will need to download the fixture library from the link below then use the fixture tools on the other link to either export the fixtures you require to a file or create a CFT file us
http://zero88.com/support/index.php?/Knowledgebase/Article/View/58/
You can either use the fixture tools on the link below to create a CFT file to load into the desk or create a mini library fo upto 50 fixtures.
http://zero88.com/support/index.php?/de/Knowledgebase/Article/View/49/0/zero-88-fixture-tools---version-26
If you create a CFT file you load this onto the desk by going into Super user, floppy options and selecting load CFT.
If you use the mini library use the load from floppy option as normal in the assign fixtures menu.
Keith Rogers
