jrphs Posted May 11, 2014 Report Share Posted May 11, 2014 Hi We have recently bought a Solution and can't fault it! I am still working my way through its functions etc. I have been programming a show on it and hit a small snag which I can't work out! I have programmed a couple of chases into the cue stack but when I have programmed a cue after the chase cue, the moving lights will dim as they should but they continue to run the chase! I have tried to home them and turn the intensity to 0% then programmed the next cue but they still move. It wouldn't be so bad but they are quite loud when they move! Am I doing something wrong?! Thank you Jack Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted May 12, 2014 Report Share Posted May 12, 2014 Hi Jack, What version of software are you running? Are you in 'Tracking' or 'Non Tracking' mode? If 'Tracking', do you have 'Smart Tag' enabled? Best regards Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
jrphs Posted May 12, 2014 Author Report Share Posted May 12, 2014 Hi Jon The board is in 'non tracking' mode and the software version is 7.7.0 I'm sure I'm just missing something small here. Thank you Jack Quote Link to comment Share on other sites More sharing options...
