Hi
We have recently bought a Solution and can't fault it! I am still working my way through its functions etc. I have been programming a show on it and hit a small snag which I can't work out!
I have programmed a couple of chases into the cue stack but when I have programmed a cue after the chase cue, the moving lights will dim as they should but they continue to run the chase! I have tried to home them and turn the intensity to 0% then programmed the next cue but they still move.
It wouldn't be so bad but they are quite loud when they move! Am I doing something wrong?!
Thank you
Jack
Hi Jon
The board is in 'non tracking' mode and the software version is 7.7.0
I'm sure I'm just missing something small here.
Thank you
Jack
