Keyboard entry with Leapfrog 48
Ian's correct - it's the same code, so it's very rare that something user-interface related, such as this, will operate differently on a console compared to Phantom ZerOS.
This seems to work fine for me in Zero 7.8.
Naming retrospectively is the same as if you were doing it as you are programming. Sorry if you already know the following and I missed the point of the question. The following works on the Phantom Frog Leapfrog setting with software 10.12 (latest). I don't think this functionality changed across software versions.
<F2>
Dialog Box=Select type of item to name
<Memories>
Dialog Box=Select Memory Number
<Enter> or type number
Dialog Box=Name Item
<type name using keyboard><Enter>
Job done!
Nick, its possible on the Leapfrog that F2 is labeled 'Name', but certainly on Phantom Frog Leapfrog setting its in the same position on the console as F2 would be on a Fat Frog. i.e 2nd button from the left on the very top row of buttons above the Master A/B faders. Kevin
