Nizar Sabir Posted April 12, 2014 Report Posted April 12, 2014 Hello, We have bought recently the Zero88 Solution. Beside Martin and ETC fixtures we have (eurolite led theatre 36x3W CW/WW - Theatre Spot) and (Showtec pixelbar 12), which are not listed in the fixtures library provided within 7.8. Can some body tell me, how could I control the parameters of these fixtures? Quote
Jon Hole Posted April 14, 2014 Report Posted April 14, 2014 Hi, Please find attached the Eurolite fixture you requested. eurolite.iftFetching info... For the Showtec fixture, there are RGB and RGB+D fixtures available in 'Standard Fixtures'. I'd probably patch this fixture using these. This way, it's much easier to control each cell individually, and you can run effects and offset them along the cells etc. Hope that makes sense, Jon Quote Jon Hole linkedin.com/in/jonhole
Nizar Sabir Posted April 14, 2014 Author Report Posted April 14, 2014 Thank you Jon for the reply. I have never added new fixture type files. I just would like to make sure that I do nothing wrong to download the file. Shall I go on like this: Setup - Files - load User Fixtures or Setup - Files - Update Fixture file ? Quote
Nizar Sabir Posted April 14, 2014 Author Report Posted April 14, 2014 I have done it. I cancel the question. Thank you. Quote
Nizar Sabir Posted April 14, 2014 Author Report Posted April 14, 2014 But could you send me the texture type file for (ETC Led Source 4 Studio HD), because it doesnt work exactly with the LED Lustr+ Thanks Quote
