kewl Posted April 11, 2014 Report Posted April 11, 2014 hello im trying to upgrade my jester tlxtra v.3.3 to v.4 i do this instructions ; 1) Download the latest operating software from zero88.com as a .zip file. The correct operating system file for the desk must be used. Jester Range files will not load on the JesterML/JesterTL and vice-versa. Using the wrong file may leave the desk without any software loaded. 2) The desks are unable to unzip .zip files or navigate sub-directories, so first extract the contents of the .zip file to the root directory of a USB memory stick. This will be a file with the extension .jos, plus a .joh file for JesterML & JesterTL Range desks. It is recommended that only one .jos file should be on the USB memory stick at any one time. If you experience problems using the built-in zip functions of Microsoft Windows, then try Winzip (www.winzip.com). 3) Plug the USB memory stick into the desk. 4) Switch on the desk with the Left and Right cursor buttons held down. The Upgrade Menu will appear on the LCD and monitor screen. 5) Wait for the USB memory stick to be recognised by the desk. This is usually indicated by the LED on the memory stick flickering for a short time, and then returning to a steady flash. 6) Select <OK> using the cursor buttons, and press the Enter button. but desk couldn't find the files,i tried another USB memory sticks but i got same problem every time, desk always searching update files .but cant find them. thanks for helping. Ercan Quote
Jon Hole Posted April 11, 2014 Report Posted April 11, 2014 Hi kewl, How big is the USB stick you are using? We've heard people with similar issues try a smaller USB stick (1GB) which then works. Quote Jon Hole linkedin.com/in/jonhole
kewl Posted April 16, 2014 Author Report Posted April 16, 2014 yeah i was tryin 8gb usb sticks,1 gb works. thank you for help. Quote
delmawatson Posted August 22, 2018 Report Posted August 22, 2018 On 4/11/2014 at 10:57 AM, kewl said: 2) The desks are unable to unzip .zip files or navigate sub-directories, so first extract the contents of the .zip file to the root directory of a USB memory stick. This will be a file with the extension .jos, plus a .joh file for JesterML & JesterTL Range desks. It is recommended that only one .jos file should be on the USB memory stick at any one time. If you experience problems using the built-in zip functions of Microsoft Windows, then try Winzip (www.winzip.com). Expand Winzip creates archives only in zip format. 7zip creates archives in zip, 7zip (7z), bzip2 (bz2), and a few other formats. 7zip format generally compresses better than Winzip in their native formats, but is not as fast. Both are based on LZ77, which compresses by replacing string matches with pointers to earlier occurrences. The zip format uses deflate, which encodes matches using Huffman codes. 7zip uses LZMA, which uses context models and arithmetic coding to encode matches and literals. Context modeling is slower but compresses better. Moreover, 7zip supporting much more compression formats. Quote
Karam ellah Posted September 6, 2020 Report Posted September 6, 2020 Hi i am looking for download software jester ml 48 and not found it can you help to send me link to download it thanks Quote
kgallen Posted September 6, 2020 Report Posted September 6, 2020 See this page: https://zero88.com/control/jester Quote
