Lufferov Posted April 5, 2014 Report Share Posted April 5, 2014 I have a Pulse LED block that has 4 cells, it's a 13 channel unit with the following attributes: 1 - Red 1 2 - Green 1 3 - Blue 1 4 - Red 2 5 - Green 2 6 - Blue 2 7 - Red 3 8 - Green 3 9 - Blue 3 10 - Red 4 11 - Green 4 12 - Blue 4 13 - Intensity How should I configure the fixture for use with the Leap Frog 48? I need control of each cell individually with I'm assuming virtual intesity? Is it also possible to use the colour picker? Basically, I'd like to have access to as much of the effects palette as possible so I can generate colour chases along the cells etc... Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted April 5, 2014 Report Share Posted April 5, 2014 Hi Lufferov, Personally, I'd probably patch this as 4x RGB no Dim fixtures (available in 'Standard Fixtures') and then put the Intensity channel on a normal channel fader if I had one spare. This way, it's much easier to control each cell individually, and you can run effects and offset them along the cells etc. Regards Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Lufferov Posted April 13, 2014 Author Report Share Posted April 13, 2014 Thanks Jon, this worked a treat, though when you are using 16 of them, that means you have to keep track of 64 fixtures! Quote Link to comment Share on other sites More sharing options...
