uli-s_kn Posted March 17, 2014 Report Posted March 17, 2014 Hi, I updated from ZerOS 7.7 to 7.8 last Saturday and the Desk worked slow when I changed a Palette on die MFKs or switched to "Special". It took about 3 sec after pressing the Key till the change on the Display-Labels started and about 1 sec to finish the operation. Also Swiching between Submaster-Banks took this time. Today i switched Back to 7.7 and so back to normal Timing. Again to 7.8 an again slow reaction. I also resetted the Desk an only loaded Setup an Palettes from an Showfile, or another old Showfile. Same slow speed. Finally back to 7.7 and back to normal Timing. And the USB-Keyboard (Asus UK-Layout) didn't worked also under 7.8 (under 7.7 it works fine). Any Ideas? Greetings Uli Quote --you learned how to creep and you learned how to crawlbut you never really learned anything at all
Jon Hole Posted March 18, 2014 Report Posted March 18, 2014 Dealing with off-forum Quote Jon Hole linkedin.com/in/jonhole
ziglight Posted August 4, 2014 Report Posted August 4, 2014 Hello I'm a new member on this Forum; I am a light and sound ingeneer living in France; using Sirus and (a new) Solution Desk I had the same problem : I switched on 7.8 on my Solution and changing MFGs slowed down (not good on live shows !!!) so I went back to 7.7 (after reading this topic) but I really get used to some features in 7.8 ... so I don't know what to do, because some features in 7.8 are extremly useful in live shows.... is there a chance to get this "slow-down-effect" in 7.8 fixed ??? Jon Hole : what do you mean : ""Dealing with off-forum"" ??? thanks for any answer.... Quote
iank99 Posted August 5, 2014 Report Posted August 5, 2014 @Ziglight - "Off Forum" means that Jon has sent an eMail to the original poster which sometimes leads to them being invited to try beta release software. Zero88 are aware of the issue that you've experienced - there are a couple of other posts here complaining about it too. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
ziglight Posted August 5, 2014 Report Posted August 5, 2014 thanks for that reply... if there is a possibility to test a Beta-OS, I would be interested... the "slow-down-effect" depends on what one is doing on the desk... sometimes its nearly normal (like in 7.7 with a really slight delay).... but sometimes it gets 2 seconds (or more) before the LCDs change. the page seems to change nearly immediatly; for exemple on changing "on the fly" for fixture-selection (or something else), selection can be made in sort of a blind-mode (without seeing anything on the LCDs for 1 or 2 seconds..) and the selection is valid immediatly, even if nothing changed on the LCD screens for instance (the screen-change comes on later) so I think the delay is only on the LCD screens, but not on the page or mode change ! (hope my explanation is not too confused - my english is not so good... ) Quote
Jon Hole Posted August 5, 2014 Report Posted August 5, 2014 Hi Ziglight, You should have just received an email from me - if you haven't, please let me know. Best regards Jon Quote Jon Hole linkedin.com/in/jonhole
vivo1111 Posted December 2, 2014 Report Posted December 2, 2014 Hay together, what's the update from 7.8 to 7.8.1?is the solution back faster? greetz willi Quote
ziglight Posted December 2, 2014 Report Posted December 2, 2014 On 12/2/2014 at 9:42 AM, vivo1111 said: Hay together, what's the update from 7.8 to 7.8.1? is the solution back faster? no ! Quote
uli-s_kn Posted December 2, 2014 Author Report Posted December 2, 2014 Jon Hole wrote in the Answer on Topic http://zero88.com/forum/topic/7012-zeros-781/ Quote We're working on 7.8.2 which will solve your problems. And we are waiting ... :-) Quote --you learned how to creep and you learned how to crawlbut you never really learned anything at all
vivo1111 Posted December 3, 2014 Report Posted December 3, 2014 Thank you - then I will have to continue to wait. Perhaps there is a Christmas present....-) Quote
Jon Hole Posted December 5, 2014 Report Posted December 5, 2014 On 12/3/2014 at 10:53 AM, vivo1111 said: Perhaps there is a Christmas present....-) We're hoping, but it maybe a New Years one. The latest beta's are faster, but not as fast as we would like them, so we're still going through the code :-) Quote Jon Hole linkedin.com/in/jonhole
