Please could someone advise on replacing battery on Jester 24/48ML,
Desk is forgetting fixtures when powered down.
Have a long session tomorrow plotting propose saving show to USB memory, but would like not to have to say to school keep the power on...
Is it a simple case of base off and replace CR2032 battery?
Regards
John Mac.
Hi John,
Yes, take the front panel off (be careful, there are cables connecting the two pieces of metal work) and replace the CR2032 battery. Once you power on, you will get the error again until you go into Setup and reset the console.
Remember you should always take USB backups anyway!
Best regards
Jon
Thanks Jon,
Mission accomplished, Battery replaced pressed OK to clear error message, into setup mode and then reset Desk.
load backed up show off USB stick, and away we went with programming 61 cues, (saved back to the stick). Easy......
Regards
John Mac.
