hundy Posted March 8, 2014 Report Posted March 8, 2014 Hi, this is probably a really stupid question with a really obvious answer but ever since I have upgraded the software playback of memories is acting differently - i'm guessing because of the resetting of the desk. Before when playing back memories if i needed to 'add' an extra light or lights (because of actors moving out of position for example) using the faders I could do so but then this 'extra light' would automatically be taken out when I pressed GO to move on to the next memory. Now the lights that I have added stay on unless I manually bring the faders back down again. Can you tell me what mode or button I need to apply in order to turn this back on? thanks Quote
Jon Hole Posted March 9, 2014 Report Posted March 9, 2014 Sounds like you are in tracking mode, which allows any changes you make to 'track' through (if you want to add that channel into multiple memories, for example). You can completely turn this functionality off by going into SETUP > Desk Setup > Memory Defaults and then turn off tracking. Or, if you think you may want to use tracking, you can press 'Special' and turn on 'Cue Only' which, when on, will only update the cue you are in. Quote Jon Hole Global Product Manager, Systems and Control
hundy Posted March 9, 2014 Author Report Posted March 9, 2014 Hi, thanks again for replying. the board is definitely in non tracking mode (or at least it says it is)... Quote
Jon Hole Posted March 9, 2014 Report Posted March 9, 2014 Do you have a showfile from before you updated the console, and a showfile from now, so we can compare settings? Quote Jon Hole Global Product Manager, Systems and Control
