Graanaas Posted March 5, 2014 Report Share Posted March 5, 2014 Hi! I badly need a fixturefile for our new LED BARS (I need a fixture for the 24ch option). It is Stairville Led Bar 240/8. Can you please make one for me, i have a Jester ML 24. Best Regards André Aka ADir Attached Files stairville 240 8 RGB LEDBAR 30.pdf Quote Link to comment Share on other sites More sharing options...
mikeb Posted March 5, 2014 Report Share Posted March 5, 2014 Hi there, Try the attached file Regards Mike Stairville 240 RGB Bar.ift Quote Link to comment Share on other sites More sharing options...
Graanaas Posted March 6, 2014 Author Report Share Posted March 6, 2014 Hi! I ran in to a problem. The consol indicate that there is "wrong file type" (when i try to update the fixture lib) Regards André Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted March 6, 2014 Report Share Posted March 6, 2014 Hi André, The file Mike has kindly created is a single fixture profile, not a full library. To use this, go into SETUP, choose 'Assign Fixtures', then 'Add Fixtures', and on the multifunctional keys, instead of choosing 'Fixture Library', choose 'USB' instead. Everything else will be the same - the console will ask you to select the manufacture, then the fixture type, etc etc Hope this helps Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Graanaas Posted March 6, 2014 Author Report Share Posted March 6, 2014 Hi!! Thanks for all of your help I will try the last instructions and then i recall back! Have a nice day!! Best Regards André Quote Link to comment Share on other sites More sharing options...
Graanaas Posted March 6, 2014 Author Report Share Posted March 6, 2014 Hi!! Thanks to you Mike The fixture work! (But I ran into another problem now) Correct me if I am wrong, There is some inbuild programs in the LED bars, (these on the video in link below) http://www.thomann.de/se/cat_videoblog~ncx.html?tab=play&vid=2031 I want those program to work on my light console. Is that possible? Best Regards André Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted March 6, 2014 Report Share Posted March 6, 2014 You only get those pre-programmed functions in 2 channel mode, not in 24 channel mode. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
mikeb Posted March 6, 2014 Report Share Posted March 6, 2014 Please find attached file for 2, 3, 5 and 24 DMX modes. Jon: Can you check the 2 and 5 channel personalities over. Many thanks Hope it's of use. Regards Mike Stairville 240 RGB Bar.ift Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted March 6, 2014 Report Share Posted March 6, 2014 Looks good. The only change I would make, which doesn't affect André as he's using a Jester, is to format the 'long name' like this: 240 8 RGB Bar : 2 Channels 240 8 RGB Bar : 3 Channels 240 8 RGB Bar : 5 Channels 240 8 RGB Bar : 24 Channels ZerOS sees the 'space colon space' as an instruction that the 'model name' has finished and the 'mode name' has started. This is used in the Patch Wizard when you choose the model first, and then the mode. Stairville 240 RGB Bar (1).ift Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Graanaas Posted March 6, 2014 Author Report Share Posted March 6, 2014 Hi! I can not explain my gratitude! Thank you very much! Best Regards! André Grannas Have a good weekend! Quote Link to comment Share on other sites More sharing options...
