mattdyas Posted February 10, 2014 Report Posted February 10, 2014 while building a chase there seem to be a problem where the first step lights get stored in the following steps. i have not come across the problem before on leap frog, wondering if its a know bug. i have tried different ways programming each step but seems to be still doing it. Quote
Jon Hole Posted February 11, 2014 Report Posted February 11, 2014 Hi Mattdyas, This sounds like a tracking issue. Can you post your showfile up and let us know which chase you are getting the problem in? Quote Jon Hole linkedin.com/in/jonhole
Laurent Posted June 24, 2014 Report Posted June 24, 2014 Hi ! I have the same problem When i program a chase in submaster or memory the first step does not work ! Quote
Jon Hole Posted June 25, 2014 Report Posted June 25, 2014 Hi Laurent, What version of software are you running? Please can you upload a showfile and tell us which submaster is causing the problem? Thanks Jon Quote Jon Hole linkedin.com/in/jonhole
Laurent Posted June 25, 2014 Report Posted June 25, 2014 Hi Jon The Version is 7.8.1 (original version of the console when I bought it) I tried several submasters and any have this problem Thank you Quote
Laurent Posted June 25, 2014 Report Posted June 25, 2014 Ok, I had forgotten to "return to the Submasters Windowand move the cursor out of the Step field." Sorry Quote
Jon Hole Posted June 25, 2014 Report Posted June 25, 2014 That's ok, no problem :-) So all sorted now? Quote Jon Hole linkedin.com/in/jonhole
Laurent Posted June 26, 2014 Report Posted June 26, 2014 I don't understand anything ! The problem is yet again with any submaster or memory...Yesterday, everything worked normally and I thought I had found the solution... Here is my showfile with a simple three step chase. Fader 1 step 1, Fader 2 step 2 and fader 3 step 3. first step does not turn on (but is saved in the chase) Maybe I forgot something !? Is it a bug ? chase submaster.isf Quote
Jon Hole Posted June 30, 2014 Report Posted June 30, 2014 Private email sent Quote Jon Hole linkedin.com/in/jonhole
chuckebrink Posted August 27, 2014 Report Posted August 27, 2014 (edited) Hey, i have got the same Problem. I create a chase and the first step is a blackout. The next steps work fine, but the first is always a blackout. Is this a feature or can be deactivated? thanks for your help, chris ps.: os: 7.8.1 Edited August 27, 2014 by chuckebrink Quote
