Ljauric Posted February 2, 2014 Report Share Posted February 2, 2014 Hi, I have buy a occasion fatfrog and everythings works perfect. Only the leds under the channel faders does't nothing. Can it somewhere switch on/off Hope some can help me. Raymond Quote Link to comment Share on other sites More sharing options...
PeterV Posted February 2, 2014 Report Share Posted February 2, 2014 Hi Raymond The LEDs inside the flash buttons are normally off as they are only used when programming various things, like palettes. They don't light up to say a channel is patched or is in use or anything like that. Do you have all the necessary manuals, as you can download them from here? If you have just bought the Fat Frog, do you know the condition of the internal battery (if not I would replace it now) and secondly does it have the final version of the software 10.12 installed? Peter Quote Link to comment Share on other sites More sharing options...
Ljauric Posted February 2, 2014 Author Report Share Posted February 2, 2014 Hi Raymond The LEDs inside the flash buttons are normally off as they are only used when programming various things, like palettes. They don't light up to say a channel is patched or is in use or anything like that. Do you have all the necessary manuals, as you can download them from here? If you have just bought the Fat Frog, do you know the condition of the internal battery (if not I would replace it now) and secondly does it have the final version of the software 10.12 installed? Peter Many thxs for the information! Quote Link to comment Share on other sites More sharing options...
