Paul SWAV Posted January 30, 2014 Report Share Posted January 30, 2014 Hi I've been trying to fix this Leapfrog with no luck. V10.12.1 OS It boots up no problem, the leds on the dmx out are lit, everything appears to work, but no control out of the dmx. I even tried swapping the dmx board from a fat frog, it works on the fatfrog, but it's dmx doesn't on the leapfrog,I swapped them back after, as I know they aren't exactly the same. I tried cleaning the contacts on the memory card. Thanks Paul Quote Link to comment Share on other sites More sharing options...
iank99 Posted January 31, 2014 Report Share Posted January 31, 2014 The DMX Cards are the same card, except on the Fat Frog there are a couple of links to make it output the same DMX universe on the two connectors (on the LeapFrog there are two universes of course). If there isn't any DMX coming out then the problem is on the mainboard itself, the good news is that the board is possibly repairable/replaceable being a LeapFrog. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
KWR88 Posted January 31, 2014 Report Share Posted January 31, 2014 Hi Paul, You have mailed me direct on this as well so will continue with this from there. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com Link to comment Share on other sites More sharing options...
