jayartibee Posted January 30, 2014 Report Posted January 30, 2014 As I'm an ex Sirius 24 chap, I'm confused by one thing. Using a Jester 24/48 with just 24 dimmer channels, is there a way of showing just 24 outputs on the monitor? I'm getting confused - is output 48 simply sent to dimmer channel 24 and so on (as well as output 24) ? Quote
iank99 Posted January 31, 2014 Report Posted January 31, 2014 No, the desk actually outputs 48 distinct DMX addresses, which (unless you've repatched) are usually 1-48 which correspond to the faders on the front panel. In 'normal' mode - the faders control 1-24 over two presets but in wide mode faders 25-48 control channels 25 upwards. I don't believe (but Jon will leap in and correct me if I'm wrong) that there is a way of reducing the channel count on screen. In theory - you might still have channels running off DMX 25-48 via an aux, so it would be nice to see them running? Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
jayartibee Posted January 31, 2014 Author Report Posted January 31, 2014 So normally I would set up states on the old Sirius on one of the B presets. Which preset do I use to set up a memory state on a Jester? Quote
iank99 Posted February 3, 2014 Report Posted February 3, 2014 You just set the state and record it - it's one of the nice things about the Jester and Solution (and the Frog range before them) that you're not constrained to using a specific preset to program memories. The only thing you need to aware of is that the Faders always affect the output of the desk, so if you have a memory playing back - then the faders will also affect what you see on stage. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
jayartibee Posted February 5, 2014 Author Report Posted February 5, 2014 What I'm being very dense about is that it seems to be permanently in Wide mode when Programming. I can't put both presets into '1-24' I've only been practising blind, with no dimmers attached yet. What will the B presets do in Program mode with only four betapacks? Sorry to be so thick Quote
iank99 Posted February 5, 2014 Report Posted February 5, 2014 If you look at the right hand end of the flash buttons for "Preset B" you'll see a "Page B" with two LED indicators next to it. In Preset Mode - by default (I think) the indicator labelled "1-24" should be lit which shows that Preset B is operating channels 1-24, if you press the button once, then the indicator changes to "25-48" which shows that Preset B is now controlling channels 25-48. In Program Mode, you use the "Page A" button to the right of the Preset A flash buttons to select the channels controlled by the faders in the same way. The "Page B" button in Program mode selects which page of submasters you will save in to i.e Page 1 of 1-24 or Page 2 of 25-48 if you're recording scene/submaster memories. When you're in Program Mode, if you have scenes recorded on to faders then when you move the fader up on Preset B - any channels recorded in that scene will get added to the outputs of the desk alongside whatever you set using the Preset A faders. It's also worth remembering that the highest of the two levels for a channel will take precedence e.g. if you have channel 6 recorded at 65% in submaster 6 and then set Fader (A)6 to 45% - moving submaster 6 will cause channel 6 to go higher if you move it to "full". In some respects - this part of trying the desk needs to be done with a dimmer and a couple of lanterns connected. Hopefully that makes sense? The manual is a bit obtuse around this side of things but from bits I hear - it's on the list of "To Do's" at Zero. Quote Ian Knight aka The Service Guy - www.serviceguy.co.uk
