Hi
I was wondering if its possible to fan effects
Here's what I'm trying to achieve.
I have a linen of movers fanned across the front of the stage and I want to " ripple" a tilt across them.
I thought if I chose vertical line from the effects menu I could some how fan this across the fixtures
What's the easiest way to do this
Thanks
Hi Lightmaster,
Yes you can do this. If you hold down the SHIFT button whilst moving the 'offset' wheel, it will fan the offset across the fixtures. This will offset them in the order you select the fixtures (if you have selected them using a group, the group will have remembered the order you selected the fixtures when you recorded the group).
If you want to change the fan settings (from the middle out, for example) hold down SETUP + EFFECT together, and change the 'Shifted Wheel Mode' setting.
Best regards
Jon
