Hi Little Man,
Any USB keyboard should work - but we advise the simpler the better, so try and avoid keyboards that are backlit, have "media keys", or USB ports on the back etc.
Are you aware that when you go across to the 'name' column, and press ENTER, the Multi-Functional Keys turn into a basic keyboard to allow you to input a name? An external keyboard is a much quicker solution, but this is a helpful solution if you don't have a keyboard with you.
