I've got 2 Fat Frogs, running 10.9.1, with badly outdated fixture libraries. I've downloaded the filtered .ift file, but it's still to large for a 1.44 floppy.
I have the tools to create smaller .ift and .cft files, but the floppy system itself is stopping me.
A disk formatted by the desk is FAT12. My PC wont' read FAT12.
If I have the PC format the disk, the Frog won't see or read it.
My Mac will see and read/write the FAT12 format.
When I format using the Frog, create the file on the PC, and load it onto the disk using the Mac (yea, I hear ya), the desk will see the disk but not the file when looking for .cft files, and won't see the disk at all when looking for .ift files.
I'm running out of ways to put this together. Help?
What do you mean your PC won't read the floppy? We have converted our FF to USB now, but before that I used to prepare floppies [including formatiing] for it using a cheap USB-connected floppy drive from my WIndows 7 PC, which the FF happily read (and wrote to for show files).
The physical floppy disk used must be 3.5” PC compatible formatted to 1.44Mb (HD DS) and not bootable. Pre-formatted diskettes worked fine for me on both the FF and other desks (such as Strand 520, Strand 300, ETC Express).
Peter
I too am using a usb external floppy drive. The PC won't write to a floppy disk (1.44 HD) that came from the desk without reformatting it first. I tried formatting it as FAT, and 16, 32, 64, 512, and default bit, but the Frog came up with "no disk in drive" every time.
Please tell me more about your conversion to USB. It may be my best solution.
Thank You.
If you format a floppy in the FF, and restart it does it give the same message or does the diskette run for a bit then desk startup as normal (which is what should happen)? I presume that you have been using it to save and load shows? If not:
  • Have you opened up the desk and check that none of the cabling has come adrift?
  • Is the memory behaving between power offs, if not change the battery as this has all kinds of undesirable effects if it goes flat.
  • Have you cleaned the diskette drive recently (you used to be able to get cleaning diskettes but might not be so easy nowadays)?
If the diskette drive in the FF is working normally when the FF formats the disk, this is a mystery although not impossible that one or other drive is misaligned to each other.
As far as converting to USB, see BlueRoom near the bottom of the first page where PaulDF says what he did which basically I copied (and detailed in following page). Beware that what you get are up to 100 x 1.44MB partitions on a USB stick which runs at the speed of a floppy disk. The changeover was very easy and has worked fine since. Also be careful there are MANY models of this drive which LOOK exactly the same on offer, only one [or a few] of which will work on the FF.
Peter
