Hello, could someone please help me out with making a custom fixture for http://www.americandj.com/pdffiles/x_move_led_25r.pdf .
I tried to make a file in the Type Editor but when I try to load it it says wrong type or something like that... (file attached)
Also, can I change 5 pin to 3 pin and then go back to 5 pin again? I have various lights.
FixTyp1.ift
Jester ML v3.3 winged with Jester 24/48 v3.4
4x Clay Paky - Alpha Spot 300
48x 1 Channel Fixtures
Hi there,
Your fixture file looks Ok.
Could you be trying to "Update Fixture file"? If so the console is expecting a Global Fixture file format. On the Solution XL, I "Load UFT" - User Fixture Type for custom fixtures that I've created - this may be similar for you?
Regarding 5 pin and 3 pin connectivity, the answer is yes - both use pins 1, 2 and 3 with a straight mapping on pins. For 5 pin DMX, pins 4 and 5 were sometimes used for a second universe on other manufacturers equipment but I don't think this was ever established as a standard.
Regards
Mike
