glenn Posted January 5, 2014 Report Posted January 5, 2014 I made a profile for this fixture, but desk only shows 6 of the 8 wheel groups??? Please help Glenn ADJ-SWEEPER.ift Quote
PeterV Posted January 5, 2014 Report Posted January 5, 2014 Hi Glenn - your definitions look fine to me. I have tried your profile on our Fat Frog and it goes back to 1 after 12 wheel groups have been displayed (as you have 6 x 2 wheel groups to allow for RGBW). I can't find the limit documented anywhere but I suspect that 12 is the limit. Hopefully Jon will confirm tomorrow. If that is so you can still get a working profile in one of two ways: 1. "Compress" your colours so they fit onto 12 wheel groups (so second group would be 1w-2r-2b and third 2g-2w-3r etc). 2. Put the four missing colour groups into beamshape or position along with the "real" parameters. Neither is ideal but both will work. I tested "1" above by deleting your 3-wheel groups and loading the profile like that and it uses 11 colour wheel groups but back to front (highest number to lowest) presumably due to parameter order. Peter Quote
glenn Posted January 5, 2014 Author Report Posted January 5, 2014 Thanks Peter for replying. I moved missing colors to beam shape wheel. it is what it is. Maybe John will add/ make a fix???? Glenn Quote
