ahepburn Posted December 18, 2013 Report Posted December 18, 2013 Hi, I am having some trouble patching four icues into my system. I have the most recent software installed. Quote
Jon Hole Posted December 19, 2013 Report Posted December 19, 2013 Hi, Do you mean the Rosco iCue? They are in our fixture library so you shouldn't have any problems. What is the trouble you are having? I need more info please! Quote Jon Hole Global Product Manager, Systems and Control
ahepburn Posted December 24, 2013 Author Report Posted December 24, 2013 The pan and tilt won't work properly, I have four of them. The pan will control #1&2 and the tilt will control #3&4 Quote
mikeb Posted December 24, 2013 Report Posted December 24, 2013 TBH, I've more experience in moving lights but to provide my thoughts... In the fixture setup on the Solution desk it is possible to swap pan and/or tilt direction. It's also possible to swap pan/tilt control too - could this be a possibility? I've just looked at a manual - can you check all the fixtures are set the same, pan/tilt movement mode, DMX resolutions all set the same? Oops, prompt edit of post as having looked at the personality I see these don't have colour, etc. Regards Mike Quote
Jon Hole Posted December 28, 2013 Report Posted December 28, 2013 The pan and tilt won't work properly, I have four of them. The pan will control #1&2 and the tilt will control #3&4 Could you expand on this please? What's selected when you are changing pan / tilt? All of them? Please upload your showfile here, and let us know the DMX addresses of your 4 iCues Regards Quote Jon Hole Global Product Manager, Systems and Control
