Hi
Are you using one of the profiles already in the standard library, if so which one(s)? What model(s) exactly are the Robe movers you are trying to control? What DMX address is each of the four units set to? Peter
Hi Sarah,
As Peter has asked, what fixtures are you trying to control?
If the fixtures have a lamp, have they been 'lamped on'? Generally, you will see a small glow coming out of the grills on the side, and sometimes from the lens too, once they have been lamped on.
Jon
