Hi
Can any one tell me how to play back multiple cue stacks on an Orb XF
I have set up a selection of chases for different fixtures on different stacks but cannot output more than one at any time
The manual explains that you select a ll the sticks using a button above the cue stack but the XF doesn't have this
Thanks
D
  • 3 weeks later...
Hi Lightmaster,
You can turn the bottom 20 faders into cue stacks by using the 'fader function' button, and then choosing 'playbacks' on the syntax keys (the 5 blank keys with the LCDs above them).
The flash buttons under the faders become the 'go' button
  • 11 months later...
Jon
Thanks for your reply
I was aware of this but it doesn't answer my question
What I'm trying to achieve is this for example. Stack 1 par can chase stack 2 moving head chase. Stack 3 colour wash chase
When I set this up if I trigger the chase on stack 1 and then Stack 2 then stack 1 stops outputting
When I first got my Orb I'm sure I managed to get both running at the same time, but can't get it to work now. I'm sure it's got something to do with the way I'm recording the chase, hope you can help
D
