At our school we have an Zero88 Sirius 24, which we want to use for our basic lighting during simple presentations. We have some modern dmx controllers, but they're not very easy to use, or are instable. To be able to use the Sirius in combination with our betapacks (2) we need a way to convert the analog signal to a DMX signal. Our controller is not equipped with the dmx-card, but I've heard there are possibilities to built one in.
Although, I couldn't find any kits, so I wonder if the dmx-cards for this controller are still available? Is there any way to get one?
Thanks in advance!
these were last manufactured back in 2000 and we quickly used up the stock we had.
You may be able to obtain one from someone breaking a desk for spares. This can be a 48 way as well as the cards are the same, just need to move a jumper to tell it is now a 24 way card.
Only thing to watch for is if you a Mk1 Sirius as these do not support the DMX cards.
Quick way to tell is if your desk has the memory card slot on the rear it will be the Mk2 ans you can fit the DMX card if you
Keith Rogers
Thank you for your reply! :)
Is there any possibility that the distributors or service centres of Zero88 have any in stock? Otherwise the only possibility is to look out for some old/spare Sirius controllers.
