Johnny Posted November 5, 2013 Report Share Posted November 5, 2013 Hello, I know this has been discussed before but I'm unable to find that thread so I'm starting a new one: Is there a possibility to move multiple memories in stack on a LeapFrog w/ ZerOS 7.7? I am re-doing old shows and I need to insert new scenes into the memory stack and I'm afraid the Insert-Function doesn't allow for enough new steps to be inserted. I'd rather move a range of memories "downwards", like memories #12 - #24 now being memories #24 - #36. Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted November 11, 2013 Report Share Posted November 11, 2013 Hi Johnny, No there isn't a way to move multiple memories in one go, however: - If you press INSERT a second time, it allows you to put in a second digit of decimal place - allowing 99 memories between two other memories. - If you go to the 'Comments' column, and press 'Enter' you get to the memories' settings. Here, there's an option called 'Next' that allows you to specify which memory follows the one you've just selected. This allows you to jump further down the memory stack, to where you can put your new memories, and then at the end, use the same method to automatically jump back up to continue with your previous memories. Hope this helps, Jon Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
