keredyelesob Posted October 8, 2013 Report Posted October 8, 2013 The function your release notes described below doen't appear to work on my desk running V7.7, was it removed, or am I missing something? I can only copy the values stored in the cue and not the values passed on from previous cues. Quote Photo Copy It is now possible to Copy (and Move) using Smart Tag and Cue Only. By doing this, cues are copied at their relative outputs, rather than their programmed values. If SmartTag is enabled when a Copy or Move command is initiated, the copied/moved cues will output the same as if they were in their original position in the stack (PhotoCopy). If CueOnly is enabled when a Copy or Move command is initiated, cues after the copied cue (and after the original position of moved cues) will output the same as before the copy/move. my example this is in tracking mode. Cue1 - Dimmer1 = 100% Cue2 - Dimmer2 = 100% (so now dimmer 1 and 2 are 100%) Cue3 - all Dimmers = 0% If I copy cue2 to create Cue4 I only ever get dimmer 2 at 100%, with this new functionality I would expect dimmer 1 and 2 to 100% as that is the scene. any ideas. Thanks Derek Quote
Jon Hole Posted October 8, 2013 Report Posted October 8, 2013 Hi Derek, Is Smart Tag enabled? You will find it by pressing 'special' and then choosing 'Smart Tag' on the multi-function keys. Regards, Quote Jon Hole linkedin.com/in/jonhole
keredyelesob Posted October 8, 2013 Author Report Posted October 8, 2013 hi Jon. yes I have tried with smart tag enabled. I think I have tried most combinations of smart tag, and cue only being enabled, but they all have the same result. note: I am enabling smart tag / cue only before I press copy. thanks Derek Quote
keredyelesob Posted January 18, 2014 Author Report Posted January 18, 2014 Hi Jon Did you manage to replicate this error. Thanks Quote
keredyelesob Posted November 29, 2014 Author Report Posted November 29, 2014 Was this copy function ever fixed or did Zero88 just give up on the idea? I still cant get it to work as described in the latest Version 7.8.1. Although this version appears to have more bugs and problems with it that ever before. what is happening to your software Zero88? Quote
Jon Hole Posted January 2, 2015 Report Posted January 2, 2015 Hi keredyelesob, We've been investigating this, and found the problem. Added as ZOS-5897, this affects Solution / LeapFrog 48 & 96 consoles only. Quote Jon Hole linkedin.com/in/jonhole
