agedo Posted September 20, 2013 Report Posted September 20, 2013 Hello! I live in Russia, I work at theater and we have a Leap Frog 48 panel, insertions is changed regularly, but the panel all the same hangs, what you will advise? Thanks! debug_20-9-2013_15-37-37.dat Quote
Franck Posted September 21, 2013 Report Posted September 21, 2013 Hi Agedo, What ZerOS software version do you have installed in the Leap Frog 48? (SETUP - FILES - DESK INFO) What is the serial number of the console? Did you contacted our distributor Svetoch Samlight in Moscow for help? Thanks Franck Quote
agedo Posted September 24, 2013 Author Report Posted September 24, 2013 Hi Franck Software version 7.7.0, serial number 0086101 11220125. It did not apply to distributors! Quote
Franck Posted September 25, 2013 Report Posted September 25, 2013 Hi Agedo, You said you would run 7.7.0 but the debug file however says 7.6.0.The issue you had was fixed in 7.6.13 as part of ZOS-5319.You need to update your console to 7.7 in order to get this sorted. http://zero88.com/support/index.php?/Knowledgebase/Article/View/366/156/ Best,Franck Quote
agedo Posted September 26, 2013 Author Report Posted September 26, 2013 Hi Franck After flashing the 7.7 console began to behave unpredictably, downloaded shows and startup submaster console freezes showing a black screen. The mistake file with .zdb expansion can't be attached to the letter how I can send it? Quote
Franck Posted September 26, 2013 Report Posted September 26, 2013 Send the file to franck (at) orbdesk.com Quote
Jon Hole Posted September 27, 2013 Report Posted September 27, 2013 Hi Agedo, Thank you for sending Franck the debug files, sorry for the problem you have experienced. Our software team have found a possible issue, and have added some code to try and fix this and give us more feedback to what is happening in the background. Would you be interested in trying this beta software to see if it fixes the problem you are experiencing or gives us a better idea of what is going wrong? Best regards, Jon Quote Jon Hole linkedin.com/in/jonhole
agedo Posted September 27, 2013 Author Report Posted September 27, 2013 Hello Jon! I need to eliminate a problem with continuous freezing of the panel, the last insertion led to threat of failure of performances, wanted to return previous 7.6.0, but at us didn't remain and at you on a site didn't find! How to correct it programmatically, or it is malfunction of iron and not to do without the address to dealers? Quote
Jon Hole Posted September 29, 2013 Report Posted September 29, 2013 Hi Agedo, You can download 7.6.0 from this link: http://cooperdownloads.com/share/ZerOS%20Software/ Best regards, Jon Quote Jon Hole linkedin.com/in/jonhole
agedo Posted October 8, 2013 Author Report Posted October 8, 2013 Hello! Have you found what some causes of freezing remote file errors which I sent to you? What should I do? Console does not turn the first time, to have to overload it 4-5 times! Quote
