Hi Agedo,
What ZerOS software version do you have installed in the Leap Frog 48? (SETUP - FILES - DESK INFO)
What is the serial number of the console?
Did you contacted our distributor Svetoch Samlight in Moscow for help?
Thanks Franck
Hi Franck
After flashing the 7.7 console began to behave unpredictably, downloaded shows and startup submaster console freezes showing a black screen.
The mistake file with .zdb expansion can't be attached to the letter how I can send it?
Hi Agedo,
Thank you for sending Franck the debug files, sorry for the problem you have experienced.
Our software team have found a possible issue, and have added some code to try and fix this and give us more feedback to what is happening in the background. Would you be interested in trying this beta software to see if it fixes the problem you are experiencing or gives us a better idea of what is going wrong?
Best regards,
Jon
Hello Jon!
I need to eliminate a problem with continuous freezing of the panel, the last insertion led to threat of failure of performances, wanted to return previous 7.6.0, but at us didn't remain and at you on a site didn't find! How to correct it programmatically, or it is malfunction of iron and not to do without the address to dealers?
  • 2 weeks later...
Hello!
Have you found what some causes of freezing remote file errors which I sent to you? What should I do? Console does not turn the first time, to have to overload it 4-5 times!
