GoPowers Posted September 8, 2013 Report Posted September 8, 2013 We have about 24 RGBW LED fixtures connected. Each time the console is restarted, the default values and home values mentioned in the Fixture Setup reset to 100 each color. I'd like to set it to zero, and stray at zero after being restarted. I've saved the show to a flash drive and reloaded it, and I get the same results. Any way to cure this? Or is there something I've overlooked. Quote
Jon Hole Posted September 9, 2013 Report Posted September 9, 2013 Hi GoPowers, Which version of software are you running? The latest is 7.7. Best regards, Quote Jon Hole Global Product Manager, Systems and Control
GoPowers Posted September 10, 2013 Author Report Posted September 10, 2013 Yes, 7.7. We just purchased it in July. Quote
mikeb Posted September 10, 2013 Report Posted September 10, 2013 Hi If I read your posts correctly, the default values for RGBW on the fixture you are using need to be set to 0 instead of 100 - what fixture are you using profile? This profile can then be checked and a adapted for you if that helps. Regards Mike Quote
