We have about 24 RGBW LED fixtures connected. Each time the console is restarted, the default values and home values mentioned in the Fixture Setup reset to 100 each color. I'd like to set it to zero, and stray at zero after being restarted.
I've saved the show to a flash drive and reloaded it, and I get the same results.
Any way to cure this? Or is there something I've overlooked.
Hi
If I read your posts correctly, the default values for RGBW on the fixture you are using need to be set to 0 instead of 100 - what fixture are you using profile? This profile can then be checked and a adapted for you if that helps.
Regards
Mike
