Stateside Moving Light Posted September 5, 2013 Report Share Posted September 5, 2013 Hi All I have an old Frog 2 with 2 usb ports on front (010) I have just tried to update this to latest version of Zeros 7.7.0 It was a disaster! loads of failed updates. and no way back. went back and put 6.0 on and now LCD screen is unreadable, lots of lines moving from bottom to top and screen is very very faint as if the contrast is all the way down, you can just make out frog 2 on the screen then some squares. I am taking it that the older versions are not compatible with new OS Can someone confirm this. Any ideas about LCD screen Link to comment Share on other sites More sharing options...
iank99 Posted September 6, 2013 Report Share Posted September 6, 2013 I might be wrong but I think I read elsewhere here that for older Frog 2's the preferred update method was to use the CD Installer Version of ZerOS - presumably because there are 'wrinkles' in the older hardware that corrupt a USB stick installation. Here we go - found the topic http://zero88.com/forum/topic/6603-77-failed-to-install/#entry25981 Ian Knight aka The Service Guy - www.serviceguy.co.uk Link to comment Share on other sites More sharing options...
Stateside Moving Light Posted September 6, 2013 Author Report Share Posted September 6, 2013 Hi, Thanks for the reply, we used the CD to update after burning the iso file, I have now managed to load a older version 6.0 but we still have the LCD problem. It was working fine befor update but after updating LCD firmware it all went wrong The LCD is blank and only the time in the bottom right is just visible. By using shift screen I can move screens to it but they are barely visible and there is a hum bar running from bottom to top. Link to comment Share on other sites More sharing options...
Jon Hole Posted September 9, 2013 Report Share Posted September 9, 2013 Topic duplicated here: http://zero88.com/forum/topic/6620-zeros-update-on-old-frog-2/ Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
