DJ-Sound Posted August 27, 2013 Report Posted August 27, 2013 Dear all, we have a strange problem with our Fat Frog console: after a few months we tried to start it up (with new backup battery). The LEDs below the channels 1-12 are all on. If we move up Fader No.1, channels 1 - 8 raise to 78% and channels 13 - 20 raise up to 62%. Faders 13 and onwards work proper. The circuit board of the channel faders we changed against each other already, but this didn't solve the problem. Another thing I found when I opened the console is that at the blue code switch on the circuit board (channel 1 - 12) all switches are off. On the second board the first two switches are on. Maybe someone can tell me the right settings or has another solution for this problem. best regards Martin sorry about my English, it's a long time ago when I was at school Quote
KWR88 Posted August 28, 2013 Report Posted August 28, 2013 The switches are the problem. For channel 1-12 they should all be in the off position, from the picture the look like they are all in the on position not the off. Channel 13-24 only number 3 should be on which looks correct. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
DJ-Sound Posted August 28, 2013 Author Report Posted August 28, 2013 It looks much better now... I cannot understand how this happend, but it works now. Thank you Quote
