Huber Posted July 16, 2013 Report Posted July 16, 2013 Hello friends! For example: we have about 50 cues; now we need a work light on backstage during all these cues. Is there a simple command on the zero88 orbxf desk possible? (like Strand-command: channel number xy update cue 1 through 50). We are using the non tracking modus (in theatre). Many thanks Quote
Jon Hole Posted July 16, 2013 Report Posted July 16, 2013 Hi Huber, It's not possible at the moment, but this syntax has already been requested as issue ZOS-5370. You could go into Tracking Mode, make the change you want, and then jump back into Non-Tracking mode? Best regards, Quote Jon Hole linkedin.com/in/jonhole
