Edit Blind Function
An Edit Blind function has been provided for memories, submasters and SX buttons (Mambo Frog).
The Edit Blind function is accessed via the Preview function. The previous preview to edit live functionality has been replaced by the new preview to edit blind functionality.
The Edit Blind function is performed in the same way as the Edit Live function except that the DMX outputs will not be affected by any of the edits made to the generic channel or fixture parameter data, and the top line of the Main LCD will show Edit Blind.
Memories
Display the Memories screen and select a programmed memory.
Press the PREVIEW button on the front panel. The LED in the PREVIEW button comes on.
Press the EDIT button on the front panel. The LED in the EDIT button comes on and the Edit Blind function is entered.
Submasters
Display the Submasters screen and select a programmed submaster.
SX Buttons (Mambo Frog)
Display the SX screen and select a programmed SX Button
