jimbo-nomads Posted June 28, 2013 Report Posted June 28, 2013 After upgrade to 7.6.0 whenever I take any slider up & down to zero that channel will never turn back on in any cue even if it was programmed. Only fix is to power off & back on. Any ideas? Quote
jimbo-nomads Posted July 8, 2013 Author Report Posted July 8, 2013 IS this really the only occurrence of this problem? Can anyone give me a clue as to what the problem is? Quote
Jon Hole Posted July 8, 2013 Report Posted July 8, 2013 Hi, When you take a channel up and then bring it back down, you've put '0%' into the programmer, so submasters and memories can't affect that channel until you clear the programmer (the programmer always wins!). Press the clear button, and then your submasters and memories should work fine? Regards, Quote Jon Hole linkedin.com/in/jonhole
jimbo-nomads Posted July 8, 2013 Author Report Posted July 8, 2013 Hi, When you take a channel up and then bring it back down, you've put '0%' into the programmer, so submasters and memories can't affect that channel until you clear the programmer (the programmer always wins!). Press the clear button, and then your submasters and memories should work fine? Regards, Jon, Thanks for that, I'll try that next time I'm at the theatre (Next week). Would pressing the clear button after an update solve my other problem of an update not always working? Thanks, Jim Quote
Jon Hole Posted July 8, 2013 Report Posted July 8, 2013 Would pressing the clear button after an update solve my other problem of an update not always working? Almost certainly :-) Quote Jon Hole linkedin.com/in/jonhole
