Huber Posted June 28, 2013 Report Posted June 28, 2013 Hello Friends! I have a ORB XF with 7.6.0 software. How can i create a simple step by step chaser with 10 lights. If i choose the normal chaser in the effect palett with offset, the chase dont works right. (Some lights are flashing together in the effect.) I want: 1. step : 1=100%, all other at zero 2. step: 2=100%, all other at zero 3.step: 3=100%, all other at zero and so on Greets Quote
Jon Hole Posted June 28, 2013 Report Posted June 28, 2013 Hi, You can do this on a new cue stack. Select a new cue stack by typing STACK x ENTER Now, create 10 cues, Cue 1 with 1 at 100%, Cue 2 with 2 at 100% etc etc etc Then, click 'Stack Setup', choose 'Chases' and click 'Turn into chase'. When you do this, you'll get several chase settings appear. Hope this helps, Quote Jon Hole linkedin.com/in/jonhole
Huber Posted June 28, 2013 Author Report Posted June 28, 2013 Ok, thanx! I know this way, but i´d searched for an easier solution in the palettes. Many greets! Quote
Jon Hole Posted June 28, 2013 Report Posted June 28, 2013 Hi Huber, The 'effects' palettes and window are 'wave' based effects, whereas the 'chases' are step based effects Hope that clears things up Quote Jon Hole linkedin.com/in/jonhole
Huber Posted June 30, 2013 Author Report Posted June 30, 2013 Hi Jon, Ok we have about 160 RGB Bulbs (Glasson DFS3000RGB), i think this is much work to programm one cue for each bulb, but many thanks yet. Nice geets! Quote
Jon Hole Posted June 30, 2013 Report Posted June 30, 2013 You could create a macro that says: @@ RECORD ENTER @ . NEXT That would speed it up and make it very quick Quote Jon Hole linkedin.com/in/jonhole
