romalaw Posted June 16, 2013 Report Share Posted June 16, 2013 I wondered if you could advise me on using the phantom jester. I am trying to insert a few programme steps between two existing steps that have only integers assigned (i.e. no .x in the step number) and I am struggling to add more than one step. I have found a "work around" but I'm not sure if its the correct method (I'm new to the jester desk). If I use the insert button I get the extra steps x.1 to x.9 appearing and I can select one of them to programme but as soon as I press the program button all the other x.y steps disappear. If I try the insert button again on the integer step or the x.y step that was saved I cannot bring up the other 8 blank steps. What I did find was that if I save the programme to a file and reload it I can go back to the integer step, press the insert button and get the remaining x.y memories to appear and programme one of them. This seems a bit of a convoluted process, could you advise if there is a better way of adding in several steps in one go. Thanks PS using phantom ver 3.1 Quote Link to comment Share on other sites More sharing options...
JB97 Posted December 15, 2014 Report Share Posted December 15, 2014 I have found the same problem on the jester. If you select the cue number x (not x.y) then press INSERT it brings back the x.1 - x.9 Hope this helps Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted December 17, 2014 Report Share Posted December 17, 2014 Hi romalaw, Are you using an external monitor? It's a lot easier to understand the point cues if you are. On the built in LCD, you only see the current cue, so have to then use the up/down arrows to go and see the cues you've inserted Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
