pierotec Posted June 14, 2013 Report Posted June 14, 2013 how do you activate the "solo" on a submaster of frog2? piero Quote
Jon Hole Posted June 15, 2013 Report Posted June 15, 2013 Hi Piero, Hold down 'SETUP' and press the submaster flash button. On software before 7.6, this will only solo the submasters On 7.6, this will also solo other programmed values Quote Jon Hole linkedin.com/in/jonhole
pierotec Posted June 17, 2013 Author Report Posted June 17, 2013 I'm sorry but I don't find this function Piero Quote
Jon Hole Posted June 17, 2013 Report Posted June 17, 2013 Hi Piero, Sorry - my mind was in ORB Series mode, not FROG2! There isn't an option to SOLO a submaster on the FROG2. I've added a request for this feature as issue ZOS-5402 Best regards, Quote Jon Hole linkedin.com/in/jonhole
