I'm just using the Jester ML48 desk for the first time for a show this week and have a DXM to LED controller, running some RGB flex LED. I've got it working find using a fader each for Red, Green and Blue.
Just a few questions if anyone can help
1) I tried setting up a simple fixture for the LED strip, setting the start address of the DMX but this didnt work. I also tryed using the relay fixture, thinking this would switch the colours on and off but again this didnt work. It works fine assigning a fader for each.
2) When I set up a chase can I programme a default speed as it seems to keep the same slow chase setting. Can this be changed and programmed into the submaster chase?
3) When I did set the speed and had the chase programmed to a submaster, I then programmed the submaster into a memory in the show but when I recalled the memory it just stuck on the first chase (green in my case). Any ideas?
Sorry for all the questions and thank you in advance for the help.
Best Wishes
Adrian
