Hi,
I've just purchased a jester ML48 after using the Frog desks for a few years. A lovely desk!
I understand you can programme the AUX buttons - am i correct in saying these are the ones with the LCD display above?
Is it possible to set these up so I press one and it sets a DMX channel high to operate a smoke machine etc? Can I also then name them on the LCD display like you can the submasters on the Frog?
Many thanks in advance for your time.
Adrian
Hi Adrian,
AUX buttons are available on the Jester 12/24 and Jester 24/48, but not on the Jester ML Series.
You could create an 'ON' and 'OFF' palette for this, or you could create a submaster.
You can download the manual from the link below, and all the information you need on palettes can be found on page 37 onwards.
http://zero88.com/products/consoles/jesterml48/
Jon Hole
Thanks Jon, thats a great help. I know to stop trying to find out how to programme the aux buttons :)
I've tried to play about with the palettes and will keep playing.
Thanks again for your help.
Adrian
