Johnny Posted April 27, 2013 Report Share Posted April 27, 2013 Hello there. I used to use the Bull Frog desk and switched to Leap Frog 48 two years ago. One feature I am really missing is the "Transfer with time"-function the older desk offered. That way I could easily prepare a variety of chases using submasters and then simply transfer these into the cue stack. I have not yet found a way of doing so with the leap frog. Any ideas of how to do that? Or could a future uupdate solve this issue? Similar issue: Will it be possible to transfer output values from one channel to another - for example, if I have a very nice chase using channels 3 to 6, will there be a possibility to transfer that chase to channels 7 to 10? - Johnny Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted April 28, 2013 Report Share Posted April 28, 2013 Hi Johnny, Are you aware that holding down SHIFT + COPY will allow you to transfer states between Memories and Submasters? That's the closest equivalent on the Leap Frog 48. There's no way to transfer a chase across to other channels, but you can create an effect on the Intensity parameter, which can then be applied to any section of channels. You can select the intensity channels by holding down SHIFT whilst pressing the flash buttons of the channel fader. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Johnny Posted April 29, 2013 Author Report Share Posted April 29, 2013 Hi Jon, thanks for the advice. I wasn't aware of these functions. Must have missed that part in the manual. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
shuiguo Posted June 18, 2013 Report Share Posted June 18, 2013 There's no way to transfer a chase across to other channels, but you can create an effect on the Intensity parameter, which can then be applied to any section of channels. Quote Link to comment Share on other sites More sharing options...
