pierotec Posted April 8, 2013 Report Share Posted April 8, 2013 Hi, -when using the syntax RECORD GO to a sequence of multiple cue, the desk crashes. attached the debug file. -when using the direct channel selection from the Output Window and press Enter once you activate the syntax Enter Enter.-as you activate the 'solo' on Frog2 ?-strange viewing when and active TIME in the palette (picture below)for the future:-because it not enable the syntax PAGE n, very useful in creating macros for example.-you can add in the setup the time default also for the palette? as for UDF UDK etc..excuse me for my suggestions, I think they can be useful for many. Thankspiero debug.dat Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted April 22, 2013 Report Share Posted April 22, 2013 Hi piero, We're a bit confused on this one, your thread says 7.6 but the debug says you are running 7.1 of the ZerOS operating system. This is an issue that was fixed quite a while ago, so please update to 7.6: http://zero88.com/software/zeros Best regards, Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Franck Posted April 22, 2013 Report Share Posted April 22, 2013 Hi Piero, What type of hardware is your Frog2? Do you have 1 or 2 USB ports on the front? Please post a photo of your desk information screen. Thanks Quote Link to comment Share on other sites More sharing options...
pierotec Posted April 22, 2013 Author Report Share Posted April 22, 2013 Thanks Jon and Franck, the desk is frog2 new hardware, one USB (on the old frog2 from zeros7 onwards does not work well), the current release is 7.6.0, probably I was wrong to attach the debug file. I check and attach the correct file, sorry. Quote Link to comment Share on other sites More sharing options...
pierotec Posted April 23, 2013 Author Report Share Posted April 23, 2013 sintax RECORD GO in relatively rapid sequence Thanks Piero debug_23-4-2013_10-43-31.dat debug_23-4-2013_10-45-32.dat Quote Link to comment Share on other sites More sharing options...
