Hi there
When using the FROG function on 4 MAC 250, three of them went like a bat out of duck and the last one seemed to be asleep. I tried changing the order of the active ficture and re-addressing the fixtures. There was always one that was slow. - Any suggestions?
It was not the mac. It was always the last sellected fixture. As soon as I adjusted speed on the wheel, they all worked together. It was only when I started the function that there was a problem.
Donald
  • 2 months later...
This topic is probaby a bit old, but Macs have a speed setting when in Mode 4 and none in mode 2. Check what mode your macs are in.
Also, you shouldn't FROG the speed function, unless you want very wierd stuff, or nothing at all, to happen, so where is the problem from just changing the speed setting once you've FROGd the rest?
Peter Kirkup
