mattlighting Posted December 10, 2012 Report Posted December 10, 2012 Does anybody have a fixture profile for the American DJ/Elation Event Bar? I've also tried creating a fixture for this in the Fixture Type Editor but am struggling with parameters, when programming channel 2 it is asking for a LSB and a MSB value. I may be missing something really obvious here? I'm tying to get a 25 channel fixture type. Thanks in advance. Matt Quote
Franck Posted December 11, 2012 Report Posted December 11, 2012 In 8-bit you only use the LSB (Least Significant Byte) channel. 8 bit = LSB like coarse 16 bit = MSB like fine or "Most Significant Byte" Have a look at the manual of the fixture type editor. All details are described. http://zero88.com/support/index.php?/Knowledgebase/Article/View/49/156/zero-88-fixture-tools---version-26 2nd file - im8554_fixtureeditoruserguideissue3.pdf (559.44 KB) Quote
sel-live Posted November 30, 2013 Report Posted November 30, 2013 Hello mattlighting/ Zero 88 bods. Did you/ anybody manage to create this? I'd love a copy of the file if at all possible! Mainly looking for the 14 chan configuration. No access to windows PC. Nightmare! Best, Dan Quote
mikeb Posted December 1, 2013 Report Posted December 1, 2013 Hi there, Had a quick go at the personality. Hope it's Ok... Regards Mike ADJ.iftFetching info... Quote
mikeb Posted December 4, 2013 Report Posted December 4, 2013 I've added a new personality based on something Jon mentioned to me at Plasa this year. I have called it 12/3 Channel. This means that with the unit in 12 DMX channel mode you add each head as separate fixtures, each with 3 DMX channels. This allows each head to use the brightness wheel and also allows use of absolute or fan modes for movement by the desk. The downside is that the 12 channel DMX mode does not have strobe functionality. Regards Mike ADJ.iftFetching info... Quote
sel-live Posted December 9, 2013 Report Posted December 9, 2013 Thanks so much for this Mike. I actually haven't had the opportunity to try it yet but I will soon. Thanks for taking the time! Dan Quote
