DSL Posted November 13, 2012 Report Posted November 13, 2012 Hi all, I'm having dificulty in loading fixture data from floppy to my sirius 500. I have used the fiture type editor to import from the fixture library and then exported it as a uft for use in sirius 250/500, copied this file to a floppy that I formatted in the desk first but when trying to load, desk will not accept the file, says there are no fixture type files on the disc. I'm pretty sure it's a schoolboy error that I'm making, just need someone to point it out ! Thanks Rob Quote
KWR88 Posted November 19, 2012 Report Posted November 19, 2012 Hi Rob, What version of fixture tools are you using? PM on the address below to take this further. Quote Regards, Keith Rogers Zero 88 Support: support@zero88.com
DSL Posted March 7, 2013 Author Report Posted March 7, 2013 Hi Keith, I completely forgot I had posted here, things rather overtook me. I ended up writing a fixture profile directly into the desk but it would be good to know where I'm going wrong with the fixture tools software. I'm using version 2.6. Another question is how do I get the Sirrus 500 to remember brightness submaster information on power up as although I can re load the show each time it does become tedious and I'm sure that I read somewhere that there are a couple of bios settings that can be altered to make it do this. Finally, my LX guy has reported that one of the thumbwheels is becoming stiff to operate, do you have any replacements? Cheers Rob Quote
Jon Hole Posted March 7, 2013 Report Posted March 7, 2013 Hi Rob, the part number for a Sirius 500 wheel is 1198099 and it lists at £34. You should be able to buy this through your local Zero 88 dealer. Quote Jon Hole linkedin.com/in/jonhole
DSL Posted March 21, 2013 Author Report Posted March 21, 2013 Thanks for the info John, I'll get one of these ordered today. . . Rob Quote
