Reading a Bullfrog show file & converting it to Solutions XL?
Never_grew_up
In this case the extra channels are loaded as dimmer onto the fixtures section.
So dimmers 49-68 will be on fixture page 1, dimmer 69-88 on page 2 and dimmer 89-96 on page three. Any fixtures that were on the bullfrog then start on page 3 after dimmer 96.
I would then recommend you turn on the command line so you can control the channels easier with syntax entry.
Only thing of note is the output window shows only 48 channels plus your fixtures, it does not show dimmes 49-96 even when selected.
Keith Rogers
