lxkev Posted October 5, 2012 Report Posted October 5, 2012 Hi Zero 88 I've noticed you dont do the ML anymore (the unit without faders). Is there anychance you could alow a use keypad to contol the levels of the 24 generic dimmers? Please! Quote I need a new job
Jon Hole Posted October 6, 2012 Report Posted October 6, 2012 Hi lxkev, This feature is available on the Jester TL Xtra. There is no command line functionary on the Jester MLs at the moment, but I will add the request to our database for future releases. Quote Jon Hole linkedin.com/in/jonhole
joe_sp5r Posted May 1, 2013 Report Posted May 1, 2013 Hi, I have a Jester ML. I would love to access dmx channels using syntax command lines via a usb connected keyboard. Have you developed the software or incorporated it in the latest firmware upgrade. Cheers from Joe. Australia Quote
Jon Hole Posted May 2, 2013 Report Posted May 2, 2013 Hi Joe, The Jester ML has support for 30 fixtures via the Multi Function Keys, but no additional dimmers, so we couldn't add syntax entry to access dmx channels onto that console. Best regards, Quote Jon Hole linkedin.com/in/jonhole
joe_sp5r Posted May 2, 2013 Report Posted May 2, 2013 Hi Jon, yes I have been using the ML to teach students on controlling LED and moving fixtures and recording cues before going on to train them to use Lightfactory and ethernet dmx interfaces and networking. I was referring to accessing dimmer channels not fixtures. I'll just keep plugging in the LSC Atom. Cheers Joe Quote
Franck Posted May 3, 2013 Report Posted May 3, 2013 The Jester ML was designed as a wing or add-on to control intelligent fixtures for users of the 2 preset consoles Jester 12/24 or 24/48. It was not designed as a unit with preset faders or submasters and obviously the basic ML has no faders. If you prefer preset faders the Jester ML24 or ML48 are the right ones. If you like a keypad and syntax commands the Jester TLXtra is the choice. Quote
joe_sp5r Posted May 3, 2013 Report Posted May 3, 2013 Hi Franck, I was only suggesting the possibility of using command syntax of '1 thru 12 @ 50%' via usb KB with an upgrade in OS. I appreciate the differences in the Jester ML and TL range and realize you cannot 'retool' on a whim My initial question was a follow up to Jon Hole's response of 7/10/12. Thanks Joe Quote
