Please see the attached fixture file.
Please note that depending on the value you set on Channel 1, called Preset in the profile, will have an effect on the other channels.
It looks like a value between 10 - 249 causes Channel 4 and 5 to change to from controlling Red1 and Blue1 segments to being a speed and fade time for the programs.
It also looks like it disables the other LED channel controls as well.
You have not mentioned which desk you are using as the set-up of the subs may have an issue on programming or replaying from them.
Eurolite.ift
Keith Rogers
